CLK Headlight switch replacement
Len Clay
Surrey
Located a faulty conection on the headlight switch fuse box and i now have a complete replacement rotary headlight switch and fuse box module.
How do i replace it and when i do will i have toget the ECU reset.
Can i just un plug and replace or do i need to do anything else.
Len
L
Len Clay
Surrey
  • #2
Just to let others know i changed the switch tonight. Once i discovered how to get it out all i did was remove all the fuses before disconnecting. Replaced the switch and fitted all fuses . He presto all worked. The only fiddly bit was disconnecting and reconnecing the handbrake release lever.
David Nock
South Yorks
CLK/2009/320CDI
Great stuff Len. glad it's sorted. Thanks for the feedback that you can do some things to the circuits without an inquisition from the on-board management system.
colechelle
Resigned
just another note on this subject, any of mb light switchs can be swapped with out any recoding etc, as always key out of the ign when doing these, when i say switches this dont mean combi stalks or anything just the rotor light switch!!
www.W140.co.uk&www.r129.co
