CLK replacing drag link
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Hi all
I have to replace the drag links on a CLK, the tie rods and drag links come as a complete assembly, Ive had a look at the way its fitted already but I cant see theres enough clearance to move the assembly up to clear the balls joints on the drag links.
Anyone had to do this job before and found a sensible way of doing it? Ive looked on WIS and from what I can see it looks like the engine has to be removed:shock:
jib
Cole@MBS
www.mbssouthampton.co.uk
Jib, cant get my head around what links your on about, can you post a pict from the russie site!!
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Sam
Its the item with 4 ball joints attached, it connects to the steering box and both front wheels.
jib
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Sam see attached no 5 in the link.
jib
Ollie was going to do one on a CLK,, yes its all one lump.
Shall I look it up
Cole@MBS
We crossed posts, if im correct, if, dont you just lift the off side of the engine and slide it out that way??? im sure thats how i did the last one!!
Ellsy Tanners
Mars
Hi Jib,
Once you have undone the nuts and broken the joints it will remove to one side, with a little jiggling.
Undo the idler bush ball joint nut by turning the steering slightly so you can get to it with a long extension bar from the top.
Over than that you should be ok.
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
The joints are free at the wheels, the joints under the gearbox are free but there doesnt seem to be enough clearence below the g/box for the ball joints to become free.
jib
Cole@MBS
Not going against what Ellsy said but im sure the last time i did one we jacked one side of the engine up so it would clear Jib!
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
ok Sam did you disconnect the engine mount or mounts?
jib
Ellsy Tanners
Mars
Yeah you could be right mate, I am thinking of 202,s and assuming the 208, would be very similar. I cannot specifically remember a 208 so could well be.
Just fold it all up, and open it one bit at a time :D:D
Cole@MBS
Yes, if i remember correct we had to, as Ellsy above, its one of those jobs you do and forget it, but im sure it was a 208 320, we took the bolt out and jacked up the off/side, it was still a pig even then!!
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I dont understand why they make it so difficult, customer was quoted £550 inc part part alone was £202.
jib
Cole@MBS
jib
Because the cars put together in a certain way, its not spost to need bits replacing!!! before they fitted the engine and box that was already installed!!
I have the job sheet printed off if you would like it Jib
Cole@MBS
Whats the item number Malc, i have to look now!!! i take it your using WIS???
