CLK W209 front seat-back can't tilt!
MercMart0802
Southport
2011 S350 Bluetec Limo
Sorted i, a lot simpler than i thought was going to be, the cable end had just come off the handle. removed handle and surround off seat and manipulated back in to place with two screwdrivers.
Mark Fisher
CLK 220D (2007)
Malcolm, I'd love that information too! PM on the way.
Hi, new here and could do with some advice. my CLK W209 passenger seat tilt cable has broken (one of the Bowden cable strands has snapped at the latch) - anyway, ordered the part (number A2099100174 - from the USA!!!) and could do with finding the fitting instructions.
Could anyone assist?
Kind Regards
Mark
GlosRichCLK
Gloucestershire
Have you looked on YouTube?
Mark Fisher
CLK 220D (2007)
I have indeed- I thought this might be a common fault, the cable snapping that is. But, it appears not.
There’s a few on the W208 but the latch appears different (easier) to access. It looks like a strip down of the upholstery to get the new part in.
Mark Fisher
CLK 220D (2007)
Mark Fisher
CLK 220D (2007)
The drivers side looks like it’s about to go pop also. That’s all frayed on one wire also.
You can see both the wires. One to each leg, when you lift the latch.
Mark Fisher
CLK 220D (2007)
Part arrived and fitted. A little fiddly but installed in 20mins with no need to remove the seat
Hopefully you’ll see a Couple of photos of the afending part and the new one.
Mark Fisher
CLK 220D (2007)
Many thanks- I’m going to do the other side next.
Anyone had any dealings with euromerc? They ‘apparently’ have the part but when I googled them they seem to have a really bad reputation. So, I was going to order it from the USA again
John Hector
New Registration
CLK 2006 500
Thanks, will report back (with success hopefully). I remember taking it apart once, it all worked as it should with the rear cover off & was back to usual non working mode with the cover on..
Do you have the information on adjusting the seat-back fold cable?
Thanks, John
MadArgy
2007 A209 CLK200 Kompressor Sport
Hi all, I know this is a very old post, but keeping my hopes high...
Does anyone still have the cable fitment / adjustment instructions?
Also, are the cables handed or both right and left seat take the same?
Thanks in advance!
MadArgy
I managed to confirm the correct seat release cables part numbers on a detailed EPC (Mercedes-Benz Teilekatalog (Ersatzteile online). Looks like the release cables are handed. In case anyone needs them, part numbers are:
  • Left seat: A2099100174
  • Right seat: A2099100274
I've attached the parts blow-up drawing; the cable is part 330. When I get some time I'll take off the back again and see if I can figure out how to release the seat back to get a bit more space and have a better view, to suss how to change the cable... can't be rocket science...
