I have a problem with the multi-function indicator stalk on my clk! I had an intermittent problem with the windscreen wipers not working when turned to auto or permanent! Wiggling the stalk would get them working again but now they have stopped working altogether!
The wiper system is fine as they operate fine using the push-in wash wipe! So it is clearly the internal switch!
Does anyone know if there is a fix for this, is it possible to take the switch apart? Guessing it is wear and tear causing misalignment of the contacts somehow!
Car is due an MOT shortly and guess will fail!
