CLK W209 Rear Electric Window
Sel
CLK W209 270CDI
I have a W209 CLK. When you close the drivers door the window of the drivers door closes to first and then the rear window closes. The other day when I closes the door the drivers window closed and there was bang from the rear. The rear window still operates normally from the switch, but it no longer moves when you open and close the drivers door.
Any ideas as to what has broken and how do I remove the rear trim?
Sel
I will look it up and see if the fault is listed, and how to remove the trim.
You may have to remind me this evening
Sel
CLK W209 270CDI
Malcolm
Did you have any luck with this.
Sel
Tel: 020 8863 9233
