- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
Yesterday after a nice roof down drive the roof failed to full return to closed . After a lot of hassle I managed to close the roof manually so at least things are weather proof .
I’ve had a quick look at YouTube and the likely fault areas . If I get time I’ll scan the car with icarsoft later or tomorrow.
So the symptoms are :-
The roof opens correctly.
The roof 90% closes without issue to this point (not my car pictured) and all you can hear is the motor trying to work .
There are a number of micro switches in the boot area and they all make a click sound when you press them .
Does this click mean the micro switch is working ??
The likely switch (or broken wire fault for this scenario) is the micro switch that is under the lining of the bow deck that is pictured not fully seated . The switch is responsible for recognising that the rear roof window is engaged with the deck for the final movement .
Anyone any experience of this issue or advice would be appreciated .
