- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
Thought I would post a couple of pics of changing the power steering fluid , I did the E class yesterday but did not take any car pics .
Jacked the car up at the front , disconnected the return flow pipe near the bulkhead which was MUCH easier than my OM642 , nothing was in the way .
I then used a large syringe to drain the Overflow reservoir (couldn’t for some reason get a pipe into my E class reservoir ) .
There was very little moving of any of these old hoses .
I then plugged the hose from the reservoir and added another pipe (orange one) into a container for the return dirty oil .
Turned the steering lock to lock a few times with regular reservoir top ups until the new fluid came out .
Reconnected the hose and clic-r clamp then did the steering again 10 times lock to lock , checked the fluid level again .
I put the cap on then and turned the engine on for a few more lock to locks .
Lowered the car took it for a 15min drive and checked the level again…..job done . A slow 1.5 hour job .
Maybe used 1.2-1.3L of oil
