Hello,
I bought my CLK320 A208 with ongoing problem with the windows and soft top not operating properly. Originally this was occasional and for short while, but now is every day. In the morning the car is fine and windows work as it should, but after a while the red light for the soft top comes on and windows die. The soft top never really worked for me, but previous owner said that is fine now and again.
Few days ago I manage to plug it to a star diagnostic equipment that came with B1091 fault code- fault in communication with control unit N52 roll over and soft top module. The roll over bar is working fine while the switch light is off and I do not think is down to a micro switch.
Previous owner has been disconnecting battery to reset ECU's for some time and has been jumpstarting the car. Could that be the reason?
Also if ECU is faulty, can it be replaced with another second hand unit without programming to the vehicle?
Will appreciate all opinions and thoughts on the matter
Thank you
Thank you
