MarkCorrigansBoiler
Hello,
I usually use my car for shortish journeys but did a long journey of 2.5 hours recently. After stopping for petrol after about an hour, my 2003 W209 CLK320 (petrol) threw a Check Engine Light but otherwise ran fine. After stopping again later, the car would crank over fine, but would not start, after a few more minutes, I tried it again and it started and drove fine. The same thing just occurred on the drive home (after stopping after a couple of hour and trying to restart, it would crank, but not start. After a few minutes, it started and drove fine.)
I pulled the codes and the only one stored was a P0341 which indicates "Camshaft Position Sensor A Circuit Range/Performance Bank 1 or Single Sensor"
I've done a whole bunch of searching and reading and I'm a bit confused. Sue to the similarities in name, a lot of people seem to be confusing the Cam Position Sensor and the Crank Position sensor.
Do the symptoms I describe sound like the Cam (as indicated by the code) or the Crank sensor is at fault? The Internet seems to suggest the Crank being a more common fault and matches my symptoms, but the P0341 code suggests the Cam sensor.
Any help appreciated.
I'm hoping for the Cam as it looks like an easier part to replace on the M112
Thanks.
