CLK320(w209) 18'' AMG alloys, tyre pressure?
rb26inside
Anyone knows the right tyre pressure for it?
front: 225/35 rear: 255/40
Thanks very much!!
whitenemesis
CLS55 AMG '05
Does it not say inside the filler flap or the drivers door shut or the owner's handbook?
It doesn't matter the wheel / tyre size the pressures will still be as stated
R
rb26inside
Thanks a lot for your reply, i thought the tyre pressure would be different from the stock tyres/wheels.
rf065
Grossbritannien
That is not always the case and never was, television used to quote this all the time, in my opinion it is just plain wrong.
It is normal for lower profile, larger diameter tyres to require more psi than what was fitted as standard.
Russ
paininthecclass
tyre pressures
Russ
Tyre pressures go by the weight of the car the profile of the tyre the size of the rim and the width of the tyre, your tyre pressures will be different if you have 18s when ur standard wheels were 16s, many people get confused by this, and end up with to much pressure or way to little pressure, ask a tyre dealer they will have a chart.
