Clk320 w209 Fuse for CD mulichanger
P
peejayX
Can anyone help with a fuse diagram for my clk320 w209? I am looking for a fuse that controls the power to the CD changer in the glove box. I get an error message saying 'NO MAGAZINE', but the magazine is in possition, but I cant eject it, and there is no sign that power is getting to the mutichanger.
Fuse 20 in the rear fuse box
P
peejayX
Hi Malcom, I looked for fuse 20 in the boot, I found fuse 1 to 16, they look like bog standard car fuses, but no's 17,18,19 & 20 on the bottom of the board, don't look like fuses to me. They are little upright coloms about 5mm square, are these fuses? If so how do they come out. I tried to wiggle them gently, but no sign of any movement. any idea?
If you put up the first 6 vin numbers I will do another search
P
peejayX
Would this be a VIN number? WDB2093652F07176, hope this identifies it.
I have been to the same car as your and as of 01 06 04 fuse 20 is the one for the CD changer code 819 in the glove box, it also controls the rear blind if you have one
P
peejayX
Sorry, last 6 digits should read 071764. The year of my car 0 3.
If you have no fuse 20 fitted then this could be why the changer does not work
fdfd
New Registration
03 CLK convertible - Fuse 64 did it for me - main engine bay fuse box, front left - 10A. Command, Radio and (it seems although not documented in the fuse sheet with the car) CD changer. Please check before disconnecting etc to make sure not live.
