CLK55 W209 Charging Fault
danielfoley
Luton
2004 CLK 320
Hi. I have a 2003 w209 CLK55.
I brought it back in October. It was water logged when I brought it (condensation). Anyway, back in January I was driving and got the visit workshop warning with the battery icon.
Changed the alternator with a LUCAS alternator. Still got the warning, 11v at the battery.
Changed the battery with a 110ah YUASA battery.
Still getting the warning. Checked battery with engine running, only getting 10.5-11v.
To check alternator I ran a jumper cable from back of alternator to battery when engine running and got 13.5v and the warning icon vanished so I know the alternator is working.
So, somewhere between the alternator positive and battery there is a fault? I've struggled to find out what it could be, I found a post mentioning an x4 unit? Apparently there is another interim fuse in the cabin under the carpet somewhere, but, I can't find where it is. I've ripped out the passenger footwell and I can see live cables but no unit?
Really struggling with this. Tempted to run a new live direct from alternator to prefuse box under bonnet.
When I took the carpet out the floor underneath was absolutely full of water.
D
danielfoley
Luton
2004 CLK 320
  • #2
peterws1957
Lancashire
I would have thought that if the interior was waterlogged it would be unlikely down to condensation alone. The condensation may very well be caused by a water leak, which would have to be traced. I'm not familiar with the CLK, but wonder whether you have a blockage in one of the drains, particularly on the bulkhead. (on my CL there are 4 drains on the bulkhead and 3 in the wiper scuttle - if even 1 blocks, it overflows and water can enter through the bulkhead). I firstly would be investigating the water ingress. As a temporary measure I'd be putting those plastic containers filled with damp absorbing crystals into the interior.( Buy from Screwfix). Very effective at moisture control. I wonder whether an earthing point has corroded to cause the problem with charging. An wiring diagram might be useful in checking a potential fault. Sorry can't be more helpful. I'm sure others will chime in.
As per above, I expect the scuttle drains (or sunroof drains (if it has one)) are blocked.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
I’d look at the scuttle drains too. Our 208 ( don’t suspect that the 209 is much different in this design) used to get water in the passenger footwell. The cause was a blocked scuttle from the windscreen, difficult to find as it had a rubber flap covering the hole. Once cleared out the problem went away though I cleaned it out on a regular basis for the next ten years.
