grayb
- May 16, 2003
- Location
- Kent
- E350CDI (S212) 2010
Has anyone got experience of whether there is a trick to draining these AMG V8's completely?
I recently had my neighbouring garage change the oil on our CLK55AMG. They are a non-specialised garage, but they work on all sorts of cars including the owner's family's AMG's etc.
They thought they had completely drained the oil, going to some lengths to ensure it was all out - making sure the filter housing was open before they drained etc. They then refilled with less than the amount that should fill the sump. Checked the electronic dipstick - said ok.
But then, shortly after, the display flashed red to say the engine oil was over filled. After some scratching of heads, it went to the MB dealer to check - they found nearly 2 litres too much oil inside!
Now, I still have the remnant of the Mobil 1 can here, with about 2 litres left in it - so they only used 8 litres. The engine takes 8.5, yet we still had 2 litres too much??
Or has someone started filling with ordinary oil - realised their mistake after 1 jug full and then switched to the Mobil 1 that we obtained specially?
