Clonkety Clonk
VitoVoom
SW London
Vito 112cdi
My 2001 Vito 112 CDI has worn anti roll bar bushes. Replacement looks a nightmare at first glance as the bush clamps are above the chassis member rather than below. Space seems very restricted and the whole powerplant seems to need jacking up to give the necessary clearance! Help?
Coulsdon Eagle
Bexhill, East Sussex
Sprinter 310CDI
replaced all of the front suspension on my Vito about 6 weeks ago, the roll bar bushes aren't that difficult to do, a bit fiddly, but do-able with relative ease, i found it best to use a ring spanner, as there's less chance of the spanner slipping off, if you can, undo the rear bolt first, same with replacing the clamp, do the rear one first, you'll probably find it easier if you remove the anti-roll bar tie rods too, as it gives more freedom to move and allows movement of the roll bar, any probs, send me a PM and i'll help if i can
www.ckinsurance.co.uk
