DSK
- Jan 31, 2019
- CLS 320 CDI, S350 Bluetec
I'm going to be doing a full suspension overhaul on the 2007 CLS 320 CDI by the end of the year (arms, links, mounts, shocks, springs etc.) as I can feel the rear top mounts need to be replaced. When I do things, I just do the whole lot, it my way of doing things, nothing cheap or half arsed.
I have options 2 and 3 below on each of my Volvo T5's and the quality is sublime but, I am going to tread carefully upgrading the CLS.
Option 1 - Bilstein B4 dampers and OEM springs.
Option 2 - Bilstein B4 dampers and Eibach Springs
Option 3 - Bilstein B6 dampers & Eibach or H&R springs.
The CLS rides surprisingly well for what it is but, it does sit low as standard with low ground clearance which I am always overly cautious with when tackling speed bumps or ramps to ensure nothing grounds/ catches. I am more than happy with the standard ride height of the car. I can get the Bilstein B6 with Eibach springs for approximately £650 which is pretty good considering the quality of the components.
Current standard (non air matic model) height
Eibach quote a 30mm front / 25mm rear drop in ride height and I can appreciate that if some models have lowered setup from the factory then, the drop can be much less than quoted. Has anyone else on the forum fitted lowered springs with new shocks to their CLS? If so, I'd appreciate your comments on them and any pictures of how the car sits would be greatly appreciated.
