CLS 250cdi (x218) (om651)
garethbevan59
Hi guys is there a way of checking the timing belt for stretch without a strip down? Also is fitting the timing belt tensioner a DIY job? I think I may have heard a weird noise for a couple of seconds during a cold start up but can't be sure. Thanks
Sent from my Pixel 3 using Tapatalk
ajlsl600
france
as far as i know, no belt here. its chain and my research indicates that i can change chain and tensioner but its not for the inexperienced or faint hearted . if mine started clanking i would change tensioner 1st in case thats the culprit i certainly would NOT be driving it about until i knew wot was going on.
garethbevan59
garethbevan59
Sorry I meant timing chain not belt
garethbevan59
garethbevan59
Also if the noise is not present at every start up then is it ok?
malcolm210
The wear can be chain guide, chain or sprocket, my guess is that if the sprocket wears there is more of a tendency to hear intermittent noise on start-up, suggest you replace all three if the job needs doing
garethbevan59
garethbevan59
Thanks for the comments but how do I know the job needs doing?
Gazwould
C250 CDI
What's the service miles intervals been like and has stop start been operating ?
malcolm210
I’d start by replacing the chain tensioner which is a relatively inexpensive job and if that doesn’t fix the problem a new chain and sprockets will be required
This is a 212 strip down to show how the chain and tensioner job is done
garethbevan59
garethbevan59
Hi, so background is that I've only had the car since Jan this year I bought car from centre of London fmbsh till 65k nothing after this now has 85k I service it myself once I got it in Jan with proper stuff - I'd say start stop been non stop in London environment
garethbevan59
garethbevan59
Talking with my local indie, and it's booked in for next week to have timing chain kit replaced he says he does them regularly, I forgot ask him what a timing chain kit entails anyone know? Is it timing chain, tensioner and pulleys?
davidsl500
I've seen kits with and without sprockets. If it's an MB Indy I would expect he will change the lot but there's no harm in asking him? Just google OM651 timing chain kit and checkout the pics..
Many believe that the start/stop function may cause wear on the chain so turn it off everytime you start off..
Gazwould
C250 CDI
Not good so not surprised , yes London is a place one would save fuel with stop start , except you don't in the end .
ajlsl600
france
get in put in key turn on hit the dissable stop start button ecco? my arse , not for me/my wallet anyway . it sure will wreck chains/starters .
Gazwould
C250 CDI
Disabled mine by pulling the 7.5A auxiliary battery fuse .
garethbevan59
garethbevan59
He says kit contains chain, tensioner and guides
ajlsl600
france
Gazwould
C250 CDI
Nothing except the auxiliary battery .
ajlsl600
france
sounds almost , for benz, to good to be true . no dash display abut that ? prob logs a fault code, guess it dont charge that batt then ? but if thats all ? grand solution
Gazwould
C250 CDI
A blessing , no eml , just a stored fault code.
Months later the battery had good voltage as I connected the charger and took no time at all .
ajlsl600
france
OK. I might try same thing...
