gjlelec
- Oct 19, 2014
- Location
- swansea uk
- 500SL 2006, 5.0L CLS, 316 sprinter 2014
Hi, i'm after some advice. I have a 2006 5.0 Ltr CLS. (69,000 miles) The problem i'm encountering is with the auto gearbox. All shifts are smooth and fine except when you are coasting up to a junction or a roundabout etc . Just before coming to a halt, the gearbox seems to make an early grab at first gear (thats the only way i can describe it) causing an unpleasant jolt. The problem is worse when the gearbox is cold but still unpleasant when warm. I've tried the "reset the gearbox" methods shown on Youtube. I'm not sure if these (various) methods actually do anything as its made no difference at all. My plan is to get my indie to change the gearbox oil and filter, reset the gearbox with Star and then see if it improves. I know virtually nothing about how an auto box works but is there anything else worth changing , (solenoid pack ? tubes ? foo-foo- valves ?) while the pan is off to potentially improve this ?
Thanks for any suggestions
