Cls320 hot start issues
Mark carr
2009 cls320
Hi guys new on here,
I have a 2009 cls 320 , it's getting a right pain the rectum to start when hot, I have had it put on a computer at the garage which said it's got dpf ,egr , sensor problems , however I didnt think they would have caused this?? I do roughly 900 motorway miles a week aswell so it isnt like it doesn't get hot enough, any ideas? Any help appreciated
V6Matty
Newark, Nottinghamshire
Cps is normally the culprit for hot start issues but a session in star would confirm with live values when hot.
Does your car get up to temperature when your running, I’ve just had my thermostat done as it would at times struggle to hit 80 even though my commute is 80 miles, during a regen it would get close to 90 but I’d noticed it was trying regens more often so certainly wasn’t happy with the lower temperature.
Mark carr
2009 cls320
It gets up to temp easily on a run, somebody else mentioned regen but im totaly clueless as to what it even is?
V6Matty
The regeneration of the DPF doesn’t sound like your problem, I honestly think it will be a CPS sensor that’s gone and giving duff info when it’s hot,
Mark carr
2009 cls320
I'll look into that ,thanks a lot mate.
ajlsl600
france
cps..its a no issue when cold,right ? however, if you can, get a diagnosis first on the hot engine, lots of stuff on these cars gets changed needlessly and at some expense.tho a spare cps is not likely to get wasted if your car is a long term keeper.
McDonald
Surrey
SL500 2004
If you tell us whereabouts you live, someone will advise on a good Mercedes specialist indie in your area. They have all the right diagnostic kit and will save you a fortune. You have a fine car, so the correct maintenance is well worthwhile.
Mark carr
2009 cls320
I live in Darlington, in county Durham.
Cheers
wahfu
Gold Coast, Queensland, Australia
W210/E320
Had a hot start issue with my W210/E320 some years back. After a lot of checking by local MB mechanic and all to no avail I decided to change the fuel pump myself and voila! No more hot starting problems since.....it is an after market pump which runs a little noisier but at least it works.
RUBBER_UNDIES
2003 w211 E270 177 BHP
Crank position sensor or camshaft sensor.
could it not be more sinple like a vacuum leak.
Anyway reading all the posts on here you are gonan spend a fortune if you was to replace whats mentioned here.
Getr to a proper merc ind with the correct diags and eexperience and you will get it sorted!
Mercserve in Nottingham cant beat Roger or Nate there!
