Clunk on foot down acceleration.
CrustyClam
Warrington
ML63 2007
I feel an issue is developing and just wanted some advice on what's it's likely to be and what you would do.
On three occasions when I've put my foot down I have experienced a pause during the acceleration, followed by a very harsh lurch/clunk sound. (Within a couple of weeks)
I used my icarsoft v2 to check TCU and no codes are showing.
Looking online (and chatting to someone on a Facebook group for ML63 owners), I wonder if I could have a faulty transmission solenoid (or multiple).
Undoubtably I will take it my local Indy for them to check but was wondering if solenoids are culprit, would it be cost effective to have a conductor plate refurbished before refitting ( if that options available).
Thx
AMGeed
Poole, Dorset
S204 C180K
Have your transmission and engine mounts checked.
M80
Derbyshire
That wouldn't explain the pause.
What mileage was the ATF last changed.
You don't recon a conductoir plate you just replace it, approx £100 for the part.
You would need someone who understands the specific purpose of the solenoids, or you might end up changing 6 I think.
Star might show more info.
Flyinspanner
Ruislip
What’s the mileage?
Have you ever had ATF changed, it could be a valve in the tranny is a bit slow to operate.
Clean atf may help if it’s been in there forever?
CrustyClam
CrustyClam
Warrington
ML63 2007
ATF changed at about 59k, first thing I had done when I bought it.
I'd also be checking transmission fluid levels.
CrustyClam
CrustyClam
Warrington
ML63 2007
Thanks for the replies. I've managed to get the car booked in for a diagnosis next Wednesday. Don't want the situation to get any worse, and cause damage that could have been avoided.
Will update once I know more
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
Does it happen when you pull from D into R. Or when just taking off ,or is it just while already moving.
CrustyClam
CrustyClam
Warrington
ML63 2007
Only noticed when moving. I just had a look at my dash cam footage when it happened yesterday, was joining the motorway at around 40mph, foot down to overtake and that's when it happened.
mercmancdi
That probably rules out prop shaft .
Looks like you would need as said a run on star first , cheaper than starting to change parts etc.
I had similar but did not happen much while driving mine was a drag when taking of and s thump when pulling from D into R it was mostly in my prop shaft
and a gearbox flush while getting sorted.
M80
Derbyshire
A thought,
check for worn bushes at the rear axle, specifically the centre A frame bush.
This still doesn't explain any delay though.
CrustyClam
CrustyClam
Warrington
ML63 2007
Ideal world would be be ATF topup, but Jonah is my middle name (well it should have been). Failing that keeping fingers crossed star will show something. If it's conducter plate / solenoids then not so bad.
Praying it's not the mechanics of the transmission.
CrustyClam
CrustyClam
Warrington
ML63 2007
A thought,
Presuming ok. I had a health check from Mercedes at the end of Jan, nothing to report.
It's a harsh delay, you really feel the clunk.
+1 on the mounts. Most likely cause.
Approx 2 hours Inc gearbox mounting. Engine can be supported from underneath.
