Code p2101 doesn't go away
CristianCisma
Mercedes A class w169 2.0 cdi
Hello everyone,
I have a problem with my Mercedes a class w169 2.0 cdi, the check engine is on and I can't manage to get rid of it.
I used a scanner and pulled the code p2101, first I tried to clean the throttle body and erase the code but it came back after two or three starts.
After that I ordered a new throttle body and changed it but the same, the engine light came back on.
I've changed the electric part between the two throttles as I thought maybe is something wrong with one of them but still nothing changed.
The throttle body has a sensor on it, changed that too but no luck.
I want to mention that the car doesn't have any symptoms, it's running as it was supposed to do, the only problem is that because the engine light is on the DPF regeneration it isn't happening.
I already had to send the DPF filter to be cleaned once and it wasn't cheap.
Let me know if you have any idea from where the problem can be. Thanks
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
This is one of those occasions where taking the car to a Mercedes specialist (not main dealer) could have saved you expense and time.
They have MB dedicated diagnostic equipment (STAR) that will confirm the fault. It may not have helped with you changing parts already.
mattkh
England
A160 W168 1999 1.6
Hello everyone,
The throttle body has a sensor on it, changed that too but no luck. Thanks
What is the mileage?
What year model is it?
When you cleaned the throttle body, what difference did it make?
C
CristianCisma
44000 miles, 2011 a class w169.
Nothing changed after I cleaned the throttle body.
Popshaz
Registered
B Class 2011 2.0 W245
Had you before the fault had a recal done on your car (software update for emissions?) I have the same fault straightaway after visiting Mercedes..
