mr rosher
first of all thanks to everyone who has helped me,
on the 8th of this month started the car after engine rebuild and / all well / no oil leaks/ no water leaks /and sounds great / good oil pressure on idle /and also very happy with myself as all the work was carried out on my own at weekends/
now over the last year since the head gasket went, iv`e had to replace,
air mass / o.v.p.r / complete rebuild of the wiring harnass from the E.C.U.to / the air mass, coils, temps sensors, and so on, / lamda sensor/ exhaust cam shaft/ throttle body/ now before the engine rebuild , no matter how many times i cleared the fault codes with the blink tester , sometimes it would be a day, sometimes three days and the codes would come back, same thing is still happening, when pluged in to pin 6 / 3 blinks which indicates ( intake air temperature sensor ) and on pin 8 / 4 blinks which indicate ( hot film mass air flow sensor ) now the only parts i did,nt replace was a small sensor that fits on the air inlet after the air mass and just above the manifold, and also some sort of sensor that fits in side the manifold under a plastic cover with two allen key bolts, can someone tell me if these could be the problem please
if it was,nt for the fact the car is hunting on idle when these codes appear i would leave well a loan, but as she is auto she keeps cutting out at cross roads and roundabouts, the car is a E280 1993 straight six, thanks for any advice
