Cold Start Valve - How to test?
aliasme
Hello. I have a 1991, 190E 1.8 which has an idle problem. It idles to low when cold then idles too fast when hot. It has been suggested that the problem may be the cold start valve which I understand can be a common fault.
I have priced up the valve and have been quoted about £60.00. Is there any way of testing to see if this is the problem before I go ahead and order one or do I have to just bite the bullet and hope that my £60.00 is well spent?
Thanks in advance of any replies.
Cheers.
Cheers.
My understanding of the cold start valve is that it is only in operation when the starter motor is turning. Have you checked the OVP relay.
Welcome to the forum. Malcolm
A
aliasme
Hi Malcolm - thanks for having me!
This may seem a bit odd but yes, I have checked for the OVP relay but it doesn't appear to be there. I'm assuming I'm not checking in the right place because presumably the car wouldn't run without it?
My understanding was that it was located in the fuse box and was located '2nd from the back' and had a fuse on top? I have the holes in the fuse box for something to plug into but there is nothing there.
Can I have the VIN first 6 number WDB124---
malcolm
A
aliasme
Not sure which 6 numbers you meant so the full VIN Number is:
2010182F849163
Cheers
A
aliasme
Thanks Malcolm - will start hunting tomorrow for the damn thing - I guess it could be somewhere other than inside the fuse box.
Cheers.
eric242340
Banned
China
Cheers.
The ISC Valve (idle speed control valve) does have known issues, however from what you have said I would check then temperature sensor first and this little item cost a lot less money.
jdsMercedes
New Registration
england
1984 W123 230E
i want to know how to test the cold start valve as my 230E barley idles.
the car has had a full ignition system a new fuel pump and filter but still runs like an old dog.
much help appreciated
if it helps vin is :1232232a054048
You remove it and hold it over a bowl, turn on the ignition and check that the spray angle is at 45º once started and warm nothing should come out of it
robparker
Taunton
Cheers.
Its behind the battery behind the plastic cover, and it itself is usually covered with a black cover, its right at the back on the left of the bigger ABS and KE ECU's.
