Colin Middleton
ShinbukanColin
Nottingham
R333SET Mercedes sl350
Hi, I have a 2007 sl350 , I have central locking issues, Soft close not working on the boot. And boot release button doesn't work. Does anyone have any useful advice?
drmw
Yorkshire
www.autonomed.co.uk
If you check the forum you will find quite a lot of advice. It would appear that the PSE pump has failed. Check the 20A fuse behind the drivers seat (it is under a false floor) - around about the middle of the row - should be the only yellow one.
If it has blown, replace it but be prepared for digging!
SL63 Mark
The South
R231 SL63 AMG
If it is just the boot soft close not working, and the doors still lock OK, that'll probably be a vacuum leak in your boot lock. Mine did the same thing recently.
Basically you need to take the boot lock out out and epoxy all the little ball valves closed. There are six I think, I did that and no more leak. It will time out after a few seconds, but if you pull the fuse to re-set it, you should hear it hissing if it is leaking. There are many fixes on t'internet, I found a YouTube video and followed it. A new boot lock is £350 from MB, so well worth fixing yourself if you can.
