Collision prevention assist plus inoperative
micky.
Lancashire
E350 AMG Line Coupe 2015
This warning came up two weeks ago. It stayed on for 3 or 4 days, covering maybe 8 short journeys all under 5 miles. I fiddled with my settings but couldn’t resolve it. My car gets covered in leaves this time of year, so I gave it a really good jet wash and polish, but that didn’t work either. I then went for a longer drive, approx 40 miles in total, and the warning disappeared, and hasn't come back.
My warranty expires in two weeks. Does anyone have any thoughts about whether this needs further investigation, or whether it was more likely to be a rogue bit of leaf debris somewhere behind the grille?
BillyBoy
W213 E400d All Terrain
Even if it turns out to not be an issue, I'd get it in the garage while still under warranty - that way if it re-occurs, there's a record of the fault in the warranty period which gives you a bit more leverage.
micky.
micky.
Lancashire
Yes, agreed. I had an MB service due next month but I’ve just brought it forward. I was sort of hoping someone might tell me this is a known issue and nothing to worry about, but like you say, better to know for sure. Cheers.
micky.
micky.
Lancashire
Likely a low battery voltage and your longer run has charged it a bit.
Cheers Mark. Would I not get a dashboard warning if my battery voltage was so low?
Mark A
Aberdeen
58 ML-320CDI.
Not necessarily but hopefully others will confirm if any other common issues. But I know from my various MB’s that a low voltage/ weak battery can cause all sorts of problems.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
No you won't get a warning , its caused by dirty bumper sensors and/or a battery sitting at 12.1 to 11.9 volts . A good 24 hour charge will see this fault go away for good.
micky.
micky.
Lancashire
Great, ta, I’m due a long drive this week so hopefully that’ll sort it out.
onefortheroad
uk.
if it improves . consider a full charge , or battery replacement if its getting old. good luck. oftr
