Comand NTG 2.5
stripe
E320cdi Brabus D6
I see loads of these up on ebay nowadays, are these new units completely self contained, in the same way that an Audio 20 is?
If so are they basically plug and play swap outs for the Audio 20 or do they require the GW and DVD units fitted in the boot?
Cheers
Michael
They are plug and play for the APS30 but you would need an antenna for the GPS,, I might have some retro fit instructions somewhere
stripe
E320cdi Brabus D6
Thanks Television
So for my E-Class with the Audio 20, this would be a no go?
rpe2
Silchester
Should still be plug and play.
As per Malcolm, you'll need a gps aerial, and also a loom adaptor.
There is a wiring set available at www.comand.co.uk
jberks
I thought command and APS30 needed an AGW? Audio 20 doesn't so I didn't think it was a straight swap as you (and I) don't have the agw. Early Audio 20s with a cassette player have an AGW but for some reason they dropped it for the cd audio 20s.
rpe2
Silchester
Not my specialist subject by any means, but I asked the question at MBGURU recently and Richard Almedia replied that basically that if you have the Audio 20 unit, and want to put in the (older) DVD based unit, it is as you suggest a camping holiday with new looms etc..
The newer HDD NTG2.5 is (almost) plug and play.
There endeth my knowledge on the matter :shock:
stripe
E320cdi Brabus D6
Thanks guys, there are a few up on ebay that come with the GPS antenna, so all I would need is the wiring loom and for the star update to be done.
Does this sound right? if so I could be going for an early christmas pressie!
Is your car a 210 or 211,,and the year please
rpe2
Silchester
Good point Malcolm, I was assuming it is a W211.
stripe
E320cdi Brabus D6
It's a 56 plate w211.
I will send you the retro fit details if you put up your Email address
stripe
E320cdi Brabus D6
Thank you very much, my email is
rpe2
Silchester
Oooh, would you mind sending them my was as well please?
Thanks in advance.
I have sent it,,you can remove your address in edit from your last post
stripe
E320cdi Brabus D6
Thanks again Malcom
jberks
So, do we know for definite if the new HD based command has an integral amp and would swap with a CD based Audio 20 (plus gps ariel obviously)?
If it does, I might be tempted myself!
I have sent the details to you, there are more sub pages that anyone can have at a later date
rpe2
Silchester
Maybe we could organise a Comand installation GTG :shock:
www.W140.co.uk&www.r129.co
