Comfort relay
paolo
I have a W124 estate, with the extra seats in the back and I know this is meant to be under the back seat, but for the life of me, I can't find it.
w124260e
If it is anything like the saloon then it is found under the rear seat n/s of car. Just push the tabs in under the bench and pull it out then lift up the insulation material. Black box with at least 3 multi plugs.
P
paolo
It's not under my seat.
Are you sure that you have the comfort pack, what is the problem
roofless
w124 e220 estate
open a window then lock the car & hold the key in the locked position to see if the window will close
roofless
w124 e220 estate
kth286
E320 Coupe 95
The windows have probably gone out of sync with the control unit (if you have it).
There is a sequence to synchronize them but as I have not had this problem have never needed to understand it.
Do a search for it.
