Command dash display??
pmh924
I have just picked up a E280 CDI 2006 (56) facelift e class fitted with command. Is there a way to get navigation instrution to display in centre of speedo. I had a 2003 E270 that displayed in instrument panel.
Thanks in advance.
Have you looked in the cluster menu,,it should be there,if it is not then some one with STAR could enable it
speedybiker
Scotland
none
As Malcolm said might need coded.
Possible reason for this might be that the previuos owner installed it after purchasing the car. I.E. Might not be a factory installed comand.
Alex.
If it's enabled 2 clicks on the left most menu button on the steering wheel will get you to the screen.
