Command online
kath
Manchester
2020. SLC AMG 43 Final Edition
I recently purchased a GLA with command online. Sometimes the vehicle on the screen is going backwards. How do I rectify this?
Craiglxviii
Cambs UK
Is the car new and if so, how long ago did you buy it?
kath
kath
Manchester
It is on a 64 plate. I bought it a week ago. My SLK had command sat nav, but I never had this problem with it
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
Sorry but not understanding this, can you explain it a bit clearer for people like me?
Or am I missing something obvious?
Robin
Frosty149
Garden of England
W207 2014 E350 coupe Bluetec D
Sounds like the nav is set to display north at the top (hence you travel down the screen when moving towards the south).
Try checking your settings on the sat nav display, if I've understood your issue correctly.
I'd go with that - if you change the settings on the SatNav to show the direction you are travelling at the top it should be fine.
kath
kath
Manchester
How do I get rid of the compass and just have it like my SLK was?
kath
kath
Manchester
Downloading the app now.
Many thanks to all who replied
Headhurts
Norwich, Norfolk
Ah! Now I understand you need setting to be heading up.
Robin
kath
kath
Manchester
The manual downloaded is just the same as the one that came with the car. Back to the drawing board!!
And the information is there:
To switch to navigation mode: press the
button.
To show the menu: slide
the controller.
To select Options : turn and press the controller.
Select Map orientation .
  • The
    dot indicates the current setting.
Turn and press the controller.
  • The map orientation is set.
  • Even has nice pictures showing you what you are looking for.
    Yours is set north up - set it to one of the other two options.
kath
kath
Manchester
Car been back to Mercedes, there was a fault on the sat nav software. It has been updated and working well.
www.W140.co.uk&www.r129.co
