Conflicting oil capacity information
Manc Rick
Manchester
W213 E220 Premium +, 2017 with OM654.
Hi, I’m going to be doing an oil change using the dipstick suction method and want to know the oil capacity.
Car is a 2016 E220 with a 2143cc OM651 engine.
Some sources say 6.5L and others say 5.5L.
I will be changing the oil filter so not sure how much that will have absorbed when I change it out.
Can anyone point me to a reliable source?
I’d also like to know the oil filter torque setting but I believe they are usually 25 n/m.
Thanks guys
Uncle Benz
West Sussex
Mainly Mercedes
It’s 6.5l with an oil and filter change on an om651. Undo and remove the filter first as what’s in there drops into the sump when you remove it. 25nm is correct.
The oil filter torque on both mine is written on the oil filter cap :)
Ron240
Fife
Sold - 2021 CLA 35 Premium.
Genuinely curious if anybody actually does this with an oil filter?
I've changed many in my younger years and just tightened them up by hand and never had a problem.
I wouldnt even know how to accurately check the torque...not that I will ever be changing one now. :D
Funkyboy
Liverpool
E250 w212 14 plate
With the electric pump you can see exactly what you get out. I did mine into 2ltr empty lemonade bottles (another benefit of the pump is no mess) got just under 7ltr out! Refilled with 6ltr and I'm happy with level on dipstick. Official capacity is 6.5 but try it after six and after you've run it as the filter takes up some of the capacity.
Get the oil well warmed up and it fly's out. Did mine in under 15mins
Gazwould
C250 CDI
With vacume manual you also see in L .
EmilysDad
Bury Lancs
ML350
The cartridge filter on my Omega had an ally cap. Even torqueing them up to the 25Nm (???) could result in them not wanting to let go when you wanted to get them off, resulting in the lump it was fastened to slackening off too. The plastic Merc cap doesn't seem able to lock up the same
Gazwould
C250 CDI
Remember the non electric handbrake and drive by cable throttle body.....
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
I always smear a little engine oil on the 'O' rings and torque to 25 NM. It's very easy to underestimate the torque when tightening without a torque wrench
Ron240
Fife
So did I because it has always been regarded as best practice, but I have never owned the type of torque wrench required for this operation.
I'm happy to say I never encountered any problems. :)
www.ckinsurance.co.uk
