Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
Ideally I am Looking for a “Contactless“ alternative to Fine Clay Bar.
The car was clayed about a year ago, then machine polished with 3M Ultrafina ( apparently hardly abraisive ) then hand polished with Autoglyms Super Resin Polish and then given 2 coats of Collinite Wax. The beading lasted for most of the year - but is now just about past it. No longer ‘brilliant’ beading, just slight beading, but once washed still feels slightly greasy when wet i.e. not got the “dry” Feel to the touch of say an unwaxed car.
I was going to redo the above (minus the machine polishing with 3M) , then I heard about Gyeon Q2M Iron.
Seems it sprays on and disolves iron particles, and possibly other contaminates??? And just rinses off.
Q. Is this / other Iron Fallout products an alternative to Claying? Or complimentary?
Q. If the latter, does one use The Fallout remover before claying i.e. to rinse off as much contaminate as possible before deploying the contact based claying?
Q. Is it worth using a Fallout remover on the bodywork? - (I see benefits on the wheels ref iron based brake dust etc.)
Q. Is 500ml enough to do a CL500 (S Class Coupe)?
Q. Identified 2 Products :
i) Gyeon Q2M Iron (more liquid) therefore easier to spray on? Costs more £21 / Litre
i) Valet Pro Dragons Breath (a thicker product). Slightly longer dwell time … is that worse for the clearcoat, i.e. sits on the clearcoat longer or better because its not such a strong a solution? Cheaper £14.50 / Litre.
Both are PH Neutral so hopefully won’t attack my clearcoat?
Has anyone used either of these or ideally both? … love to hear which you rate as best.
Note of Paramount importance to me is that it does not damage the clearcoat in any way. I would be totally gutted If it damaged it in anyway, i.e. I would much rather use a product that worked 50% removing iron particles, but did not degrade the clear-coat at all. Than a product that cleared 100% of fallout but even damaged or degraded the clearcoat even in the slightest way.
