Control Unit Recalls 96 SL320???
Claudio
:confused:
New User....well after several cold start checks and codes detecting an Air Injector problem (relay and Pump) nothing could be found. Check engine light still comes on. Any one had any similar problems are have any idea if i have a bad control unit or bad wiring harness that could cause this issue...any help is appreciated.
pascal
near Dublin
sl320/1999/3.2
Are you talking about the light on the far right of the cluster?
It could be either injection or exhaust system. If your emmisions exceed a certain limit, it will light up.
C
Claudio
yes thank you..it is the check engine light (US model)....the starfinder says it is an air injector issue....my tech said the pump and relay were fine
