Converting French E-Class for UK registration
Rosbif
Stafford
2006 E220CDI
Having recently moved over to Cannock from France, I'm in the process of converting my French E220CDI (facelift model) for UK use so I can register it here.
Replacing the LHD headlamps with RHD units should pose no problem, but I could do with some advice on swapping over the rear foglamp to the UK offside.
It seems there's no STAR swap over facility available. However, I've heard mention that there may be a jumper of sorts on the rear SAM unit that can be flipped over to send power to the other side fog lamp when the switch is turned on.
Has anyone come across this before, or have another solution?
Thanks.
tode
NW FRANCE
E300e 2024
Have you worked out the total cost of doing that? A 2006 Mercedes is worth considerably more in France, and you could upgrade for the same money in UK, with no modifications to do.
Most cars are wired for both rear fogs as I understand it :D
Naraic
2005 CL500.
They are wired as you say...the query was about getting the right one to work...I would have thought STAR...but the OP says not.
