Coolant leak - head gasket? Om601
sergiomoura
W124 200d sportline
Hi everyone,
Another day, another problem discovered:
Is is just a very small leak, and I do not have oil in water neither water in oil.
Could I just try to retorque head? Any possibly simple solutions? I have had this car for not so long and have been repairing a lot of stuff and was not ready to dig that much into the engine.
Any help would be very appreciated.
(W124 1990 om601 with 560kkms)
KennyN
Paisley
BMW 440i, Cayenne, ZX12r / ZRX11 / ZRX Monoshock
The second pic looks more like an oily leak from the rocker cover gasket ,the first pic looks like a slight coolant leak which is inkeeping with a HG failure ?
Dont know if torqueing the head bolts would accomplish much as once the gasket has gone , its gone.
K
sergiomoura
W124 200d sportline
Looks more like an oily leak from the rocker cover gasket , it is mainly a slight coolant leak with a HG failure ?
Give it a thorough cleaning and keep your eye on it.
K
Yes, there is a bit of a oil leak from the rocker cover, but that doesn't worry me, what worries me is the green coolant leak down there.
I will try to check if it is minimal or not...
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
Does look like headgasket .
bladecrazy
bolton
Its hard to say if driveing will make it worse, maybe if you were staying around your local area you may be ok.
DREAMER NO2
W124 2.6E M103 1989
If the car is a good one and worth repairing fit new heard gasket its the best fix there is . But if its a car thats not to good then pop in a container of K seal .
sergiomoura
W124 200d sportline
Done a 20km ride, it looked dry, but I suppose with the heat, coolant dries as soon as it comes out, right?
sergiomoura
W124 200d sportline
I bought it only two months ago, have been fixing a lot of stuff. I like but still not sure I will keep it long. Ordered rear shocks to see if that improves it's handling.
I also have been trying to do all the wrenching, I always done my wrenching on motorcycles, but I am trying to loose my fear (and buy tools) of touching cars...
sergiomoura
W124 200d sportline
It has some nice features, it is a factory sportline, a/c, 4 electric glass + roof, abs, 4 seater.. but 560kkm is quite bit :)
sergiomoura
W124 200d sportline
I recently changed all my hydraulic lifters.
What do I need to do more to change head gasket? Remove all fuel supply lines to injector and then the head itself?
Can I leave the crankshaft on the head? ( Just remove the sprocket?)
Lifting the head can be hand managed by a single person?
bladecrazy
bolton
how easy was doing the lifters , i have the w124 300d and have 1 or 2 noisey when cold.
sergiomoura
W124 200d sportline
Quite easy if you have the right tools and follow the sequences... I had one of them collapsed...
