Shaunm41
- Feb 26, 2020
- 2003 Mercedes CLK 270 Avantgarde
Put the heaters on full to draw heat away. The engine wont let itself self destruct. Check your coolant level also.
Looks about 110c on your gauge, but is the sensor sending the right info to start with ?
Is it higher than it usually is ? Mine runs around 95 according to the display.
One other thing to check is the make of the radiator, you have a 270cdi engine 2003 vintage. Around that time they fitted one of two rads the german Beher & the French Valao. The French one has a high failure rate, which allows the rad coolant into the cooling gallery's of the auto box.
The cost would scrap your car.I’m assuming that wouldn’t be good for the auto box?
thankfully it’s not the head gasket or .......
Regulalr maintenece to even lift the hood and check levels should be the norm.
Does the CLK not have a coolant level sensor?
