Sean Ng
- Apr 10, 2005
- Location
- Princes Risborough, Bucks
- 1996 E230 Estate, 1996 E230 Saloon, 1995 Mitsubishi FTO Coupe
Hi Guys
I need your help!
My MB is 1996 E230 estate W210 series of 140k mileage with auto transmission and air conditioner. Recently the climate control system appears to be dead. No air - cool or hot - comes and all switches on the instrument cluster do not work at all. My first response to that is something about the fuses. But all the fuses are OK!
However, I have also noticed the followings:
(1) The cooling fan starts soon after the engine is started from cold, and the cooling fan then never stops until I switch the ignition off! That is very abnormal since the cooling fan should only run when the engine temperature is very hot - not when the engine is cold.
(2) The temperature gauge shows no overheating. The engine keeps at 80 degree centigrade - the normal operational temperature for engine (I have done a road test for 10 miles in 15 minutes).
What I think the possible causes of the problem could be:
(A) A faulty sensor (but do not know which one) sends a wrong message to the electronic control unit that shuts down the climate control system, including the air conditioner, and instructs the cooling fan to be on all the time!
(B) The electric cooling fan control unit (located under left-hand front wheel arch according to Hayes manual) is faulty.
Below are the conditions of my car relevant to the situation:
(a) The coolant level and condition are normal (renewed 3 months ago).
(b) Not a single warning sign flashes on the dash board.
(c) The air conditioning sensor located in the thermostat housing area appears OK.
(d) The condition of the auxiliary belt is good.
I have stopped using the car to avoid engine overheating. I wonder if somebody can point me out the problem and advise me what to do if I intend to repair it in a DIY manner. For any further information you may need, please shout.
Looking forward to seeing your shared experience and advise.
Regards
Sean
I need your help!
Regards
Sean
