cooling probs
bigdaz1970
fife
need some help please
the other day my E320 cdi (51 reg ) started to over heat , the heater inside the car went cold also , and there was a funny grinding noise from the front of the engine ,
have found out the viscouse fan was the grinding noise , the car didnt loose any water this is the strange bit ,
as anyone got any ideas what it could be ,
i can only think it might be the thermostat packed up . ive ordered a new fan ,
any info would you please mail me on bigdaz1970@yahoo.com
thanks in advance
daz
This sounds like the water pump has packed up, so you may not need the fan.
Slip the serpentine belt off and you can then turn the water pump with your fingers, the same with the fan, they should all spin freely
B
bigdaz1970
fife
hi mate
even thow its not using any water you think it could be the water pump . the viscouse there are rubbing marks on the inside so i will change that anyway , think i shall also change the thermostate , ive not had it to long ,
is there a good way to make sure its the waterpump thanks again
The only way to check the water pump is to remove the belt, and turn it by hand to feel any roughness, , the visco fan cuts in at 80c, you cant see if the water is circulating as there is a header tank, if the pump spins easily then it should be OK
Ellsy Tanners
Mars
When you have the fan off, have a good look at the pump, take the belt off and make sure the pump spins and there is no play in the pulley.
Grinding noise are quite often the pump bearings as Malcolm said
B
bigdaz1970
fife
thanks for that . i will have a look tomorrow , just hope that what it is , i will let you know tomorrow after ive had a look .
