Beautifulbodywork
- Oct 21, 2008
The garage I use recently fixed water coming into my 1984 Mercedes 230CE by taking the headlining out from under the sunroof and renewing rotten tray. Water had been gathering in the mornings in the footwells front and back drivers side. That problem is now solved but in the process of stripping out all the carpet the garage I use in Fulham noticed corrosion to low side inside all along sidebar which is carpeted where seat belt is. The garage has put down duck tape over the corroded area but I've been told it will only be good till next MOT and if I emergency stop the corroded area will snap off including seat belt. The garage say the inner seal has gone and to repair would be costly. Can anyone suggest a place I can get it fixed, not too expensively?
I want to keep the car but this is very worrying.
