Cost of MAF (supply & fit)??? (w202)
Shala
Hampshire
S350 CDI/2010/3.0
i been told that I need to change the MAF on my car. The garage wanna charge me £527.00 in VAT. They say thats the best price I'll get. the MAF alone is £304.** inc Vat & the rest is labour because apparantly they have to connect & map it on the computer.
I'm sure someone had it done cheaper than this.
i need help asap :confused: :confused:
Find another garage, or a Bosch specialist. <£100 for the MAS and <£150 including fitting and thats at MB
Mantasr
Ayrshire
2001 c320 avantgarde
Go to Euro car parts and buy a genuine bosch MAF (mine was £160 inc vat for my w202 c200) an fit it yourself. All you need is a flat bladed screwdriver for the the large hose clip. You dont need to re-map anything. Just make sure the ignition is off before you unplug the connector on the unit.
Parrot of Doom
Manchester
Come to my house, I'll do it for £520 and I'll even make you a brew.
What a ripoff. Don't go back there mate.
Shala
Hampshire
S350 CDI/2010/3.0
So the garage was lying about having to fit it to a computer???:eek:
Yes & no, the MAS doesn't always store fault codes, so you can just fit a new one. Even if it has stored a fault code it doesn't have to be cleared straight away so just replacing the MAS is enough.
Shala
Hampshire
S350 CDI/2010/3.0
which air mass sensor to buy???
I went to euro car parts @
http://www.eurocarparts.com/ecommerce/Search_Results.asp
Done search under:
Manufacturer:Mercedes
Year:1998
Model:C180 : 202.018 111.920 111.921
Search: AIR FLOW METER
They got a few different ones for my car so which one these do i need?
BOSCH NEW n/a 434220010 AIR MASS SENSOR M111-920/41/42/44 961/70/75 ENG 124 202 208 210
£208.72
GENERIC n/a 434220011 AIR MASS SENSOR MERC 124 202 208 210 M111-920/41/42/44/60/ 961/70/75
£65.78
BOSCH NEW n/a 434220120 AIR MASS SENSOR 163 170 202 208 210638 901-903 (CHECK APPLICATIONS)
AIR MASS METER £159.95
GENERIC n/a 434220121 AIR MASS SENSOR MERC 163 170 202 208 210 638 901-903 (CHECK MODELS)
AIR MASS METER £99.96
Shala
Shala
Hampshire
S350 CDI/2010/3.0
Phone Euro car parts & they said the one I need is:
I'm gonna go & pick it up off them now & get a different mechanic to fit it
Mantasr
Ayrshire
Good stuff! I still think you should fit it yourself as it is so simple. It takes 2 mins to do. Go on give it a try. Look at the thread " How to clean a MAF" to see photos.
Parrot of Doom
Manchester
Yeah, fit it yourself. If you're uncertain what you're looking for, ask here first, but in truth all you'll need is the correct torx key. Its literally a 5 minute job.
bibamus
Whitstable Kent
Done search under:
Year:1998
£208.72
£65.78
Shala
I have a 97 C180. When I bought mine, I rang them up and gave them the details. My engine code is 111.921 ( from the service record), I got the £159.95 one, (434220120). If you look on the tube body of the MAF, you will see a number. Mine shows 0280 217 114. I gave them this number which they use to get the correct part number.
If there are any codes stored in the ECU, I believe you can reset it by disconnecting the battery for a few hours. Just connect it correctly afterwards ( + first then -) but just driving it for a while seems to sort everything out.
Good luck
Allan
Shala
Hampshire
S350 CDI/2010/3.0
waranty company decided to pay out after I went a little mentle. he garage ar charging about £527 waranty company wilpay back £333 of it so I end up paying £197 from my own pocket. its same as buiyng 1 myself as MAF + vat comes to £187 after vat this only cost me £10 more & will be fully guaranteed. After they fit it they will put it on machine to test whether its mixing air/petrol correctly.
Glenn Smith
Peterborough, UK.
This garage should be shot, honestly it's not even a 15 minute job including checking the emmissions.
jberks
The warranty company is right. I paid £400 ish for a diagnostic, a new O2 sensor (part was £100) and a MAS on my E240. So - around £300 for a Diagnostic and MAS, and that's not allowing for the O2 sensor being a bit of a bugger to do.
As everyone says, fitting the MAS is a 5 min job for a hamfisted idiot with the wrong tools so if the garage are charging you that much, and that is actually all they are doing, they are ripping you off. I actually removed the MAS when I changed the plugs because it was in the way. It really is 1 clip and a screw and it sits right on top of the engine bay so access is a doddle. Fine use the warranty and a garage, but you shouldn't be chipping in, the warranty co are paying enough for the whole job.
Shala
Hampshire
S350 CDI/2010/3.0
  • #18
deusch Motors Croydon
Shala
Hampshire
S350 CDI/2010/3.0
  • #19
just had the maf supplied & fitted by Deusch Motors Croydon. £527.68 total. The car is performing awesome but idles @ 500 revs & feels like its going to cut out. Is it because its due for a service?
Shala
