davidsl500
- Oct 24, 2004
- Age
- 122
- Location
- Home : Derbyshire at the moment !
- R172 250CDI Gone..!, R129 SL500 Gone...
Thinking caps on gentlemen and ladies please.....I want to tell you a story
MY 500SL R129 is playing up a bit, here we go....
The car is garaged and usually only comes out weekends. Last saturday it was booked in for a pre-mot and started up fine, first go as is it always does, drove about 4 miles to the station and parked up for about 20mins whilst waiting for the MOT guy to arrive. On starting it, it was running roughly - missfiring badly (never ever done this before) and it stalled as it went onto the ramp and wouldnt restart, turning over fine with the occasional "kick" and slight backfire, but nothing else. Plugs out and dried, bit of WD40 on the leads and left it 20 mins - starts up okay with a slight misfire which cures as it is left idling during the MOT Test, emmissions fine.
Drove it 20 miles to work and back again - no problems at all.
This morning i had to take it for its new set of tyres so I thought i would give it a bit of a run first this time to get it thoroughly warmed up ( i read somewhere that the dizzi caps were prone to condensation?). Drove it 15 miles or so - perfect as usual then as i approached the tyre station it started misbehaving and eventually spluttered to a halt as i slowed for a traffic island. It refused to restart, turned over fine - occasional kick and backfire. Left it 20 mins or so and it started again - not perfect, drove it a couple of miles and it was back to normal. Got the tyres (£547 - ouch !) and dropped at the MOT station for a "rubber stamp" and drove another 20 miles to work - everything fine but maybe a very very slight uneveness when idling at 500rpm in drive waiting at the lights - but no sign it was going to misbehave again.
I know that when i start it tonight to go home it will be spot again. It had a full engine service last October - leads, plugs, filters, dizzi caps and rotor arms and oil by Mercedes ( full Merc Service History) and I have done about 4,500 miles in it since.
I'm puzzled that it should play up after the longer drive, i put the first time it happened down to a short drive with weather change (it was quite chilly) and surmised that this was probably just condensation, but wouldn't have thought that i would get the problem after a good warm up whilst the engine was running. I didnt refuel at all so can rule out dodgy petrol. Unfortunately I didnt have the opportunity to check the plugs or caps second time as i wasnt suitably dressed ( or rather i was and didnt want to ruin my clothes!).
It will be a plugs out and caps off tomorrow - any other suggestions ?
