Could “excessive front wheel bearing play” cause a front wheel sensor to send a fault code and ABS and ESP not working.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Got the dreaded “ABS and ESP not available” on the dash, when connected to iCarsoft MB II says “EBV, ABS and ESP not available
codes 5101, 5102, 5106 L6/1 Left Front sensor - Historic,
I assume Left Front is from inside the cab, i.e, passenger side/ nearside?
what is EBV?
Miffed if its a sensor as these were all replaced 10,000 miles ago. Original ones lasted 44,000
As the service advisory said the front wheel bearing had excessive play 230 miles ago - I wonder could that throw a sensor code? As it wobbled?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Might sound daft but is your main battery fully charged?
Ebv is something like electronic brake distribution.
It may well be the sensor is ok but the pick up ring is giving faults ??
ajlsl600
france
Wud hav thought bearing wud have. To be pretty loose. Try lifting wss and cleaning end get torch look down see reluctor ring and check if dirty or rotton. Go from there.
Also look to see if wss is providing any speed data in live view.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
My battery is OK, ish 12.2V and I had fUlly charged it recently, did it again and was at 12.5V still faulting.
I do hope its not the reluctor ring.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
I did take it out, some gunk on it. Cleaned it, and poked some lint free rag rolled up and spun the wheel a few times to clean the ring I could just see. It seemed to be a fairly consistent colour, and no breaks I could see.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Apologies but is wss? Wheeel speed sensor. Ref live view is that the data stuff one can see on the MBII?
I will need to get the wife to drive while I monitor it.
She totally hates doing anything car problem related
ajlsl600
france
Yes and you don't have to go far to see data , however I have had data OK and still had faulty wss , when changed fault gone, nice little benz earner if going genuine on pts .
onefortheroad
uk.
Is this set up similar to that of the w211 ?? Where the sealing ring is also the abs pick up ring .
onefortheroad
uk.
It looks like it on the parts diagram, as there is only one. Or you buy the whole hub-bearing.
Do you also lose power steering at + 10 mph or is the fault intermittent?
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Went for a drive, when stationary MBII oddly said 0.64 k/hr On all sensors.
Driving all the other three sensors showed the road speed but the “suspect” wss on the front left did not even flicker - just showed 0.64k/hr.
So I guess that one is dead or the reluctor ring is shot. I would have thought if the reluctor ring was partially dead, then it might flicker an incorrect reading?
Ouch in 2019 they were £98 now they are £142.80!
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
No I do not loose power steering. Except if I put the scanner on and select that Brake section, then no power steering while the code reader is on. As soon as you deselect the Brake section power steering returns.
ajlsl600
france
That's why I fitted febi sensor. I think modern sensors are dtf. Funny how previous all lasted 20 Yr.
noonboots
R230 SL 500 2003 M113 5.0l
We're suffering from a generation of mechanics that have never seen taper roller bearings and how they are adjusted. My SL had front wheel bearing free play as MOT advisories for sound six years before I owned it. As said above it would need to be hanging off to affect the ABS sensor
onefortheroad
uk.
I agree .
Roxie
Lincolnshire
C Class 350CDI 2012
what is EBV?
Yes
Roxie
Lincolnshire
C Class 350CDI 2012
My 203 did it last week I knew it was bearing because the light came on at roundabouts. Because its esp it reacts to minor things like one wheel speed sensor variation from normal.
These sensors are active not like the old moving magnet ones that only drop out if the gap is huge.
Tel: 020 8863 9233
