Will Barber
- Jan 25, 2010
- Location
- Cheshire
- 2012 CL500 (4.7L M278)
As some of you know I've just picked up my 2005 CL500. What a car... so happy everyone said go for it!
I have two small electrically related problems with it... the first one is a bit confusing.
1. The rear electric window switches (in the rear cabin) do not light up or work the rear windows. The rear windows can be controlled with the drivers switches and I've tried sliding the isolation switch in both directions but to no avail. Fuses check out okay.
2. Both the driver and passenger seat lumbar supports are non operational. These are heated/cooling seats without massage function. Again ALL fuses check out okay. I've taken out both lumbar control switches to check and they're okay. I wouldn't have thought that the vacuum hoses on BOTH seats have failed, besides they look very pliable and intact. Obviously they are 100% pneumatic as there are no wires going to the switch, the 'thumbwheel' switches are simply valves.
Thank you for your time, very appreciated and I appreciate any help as always.
Kind regards, Will
Kind regards, Will
