Coverting a auto 320cdi to manual
Frits
Mercedes E-Class w210 2001
Hello, this is the first time i post anything on a forum, ever...
I wonder if there are any manual transmissions that will fit in my 320cdi (om613, 722.6)? I can’t seem to find any info at all around the internet so any good tips would be appreciated.
I was looking into the g56 transmission (dodge), anybody got any experience at all fitting one into the w210?
Thanks.
Frits
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Not seen any done. Question has to be, why?
Hello and welcome
It never came with a manual so you might struggle.
You might be able to use Chrysler Crossfire parts if you're lucky.
F
Frits
Hello again, thanks for all the replies.
The gearbox is already broken on the car. One of the main reasons why i would like a manual transmission is because im getting my drivers lisence in a few weeks and practicing with manual will help me develop my skills in driving stick.
I got a new 722.6 trans laying around though... so maybe i should just swap it in and get another car for manual training.
I’d do the latter and get something else to grind the gears with
Jim2
I remember many years ago, converting manuals to automatic and vice versa for a car hire company. The cars were all ford's escort's / Cortina's, and so relatively simple procedure. For converting to Automatic, a new floor section had to be welded in, pedal cluster replaced etc. But we did so many of them each year, it got to be routine. Doing the same to a Merc would be a completely different operation...and has it been done, does anyone know? Best bet would be for the OP to buy a manual, and do his test in it. In Ireland, if you do the test in a automatic, the Licence only allow's you to drive Automatics, so best bet is to do it in a manual.
Craiglxviii
Cambs UK
Why would you do this heathen thing?
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
What he said! Converting auto to manual is an enthusiast's labor of love to get the quickest, fastest, meanest, or whatever. If the OEM didn't do a manual option you've got to find a compatible gearbox, source or build the linkage, find our build the peddle box, mod a prop shaft etc And you'd still have to fool the ECU to stop it going into limp home because it's not getting signals from the automatic
M80
Derbyshire
I would have thought TCU would be the main issue,
but perhaps a less complicated issue on an earlier 210??
Jim2
OP must like a challenge......:):):)
