Hi all,
For the second time in 5 months and 600 miles, the Crank position sensor on my 126 300SE busted.
First time it bust, I simply replaced, assuming it was a one-off. This time, I need to establish why it's breaking. At $100+ each, they're not cheap, although they are easy to replace etc. But when it breaks, obviously, you cannot go anywhere as car will not start without it. Sensor always breaks at the tip, the section in the bell housing area.
Now the sensor ALWAYS breaks when giving mild acceleration, whilst cruising along. It never occurs from standing start.
Any ideas on why this is breaking. I have a couple of ideas, namely :
(1) broken pieces from previous sensor(which haven't been removed entirely) are moving around in the bell housing and causing the new one to break. This seems remote, since the sensor tip is a very lightweight object, and all the housing is plastic. But I'm not ruling it out.
(2) Flywheel isn't true - but surely this would mean more serious issues ?
Any ideas/solutions would be much appreciated.
cheers
cheers
