Crankshaft Sensor Fault Code
John77
E200 Estate 2011, 2009 SLK 200
Engine light has come on, so I ran a diagnostic with an ICarsoft Pro MB Scanner and it says that:- Position sensor 1 for the cranksaft has a malfunction. The sensor is not present. 2011 EClass CGI M271 Engine. Does this mean that it just needs replacing? Also where is this?
Replace with MB only or any make? For example Opie.
John77
  • #2
Now cleared the fault code and taken the car out and you would expect the engine light to immediately come back on, but no, not yet.
Most people would say MB only , but I did replace my E crankshaft sensor a few years ago with a Bosch one .
Probably worth buying one and putting in the car as it might be starting to play up ?
ajlsl600
france
Many times I see various sensor issues that often cause issues then go away what is one supposed to think????
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Not a nice job to replace a CPS. Its right on top of the transmission directly below the bulkhead on the passenger side.
I would buy OEM myself. I had one fitted to my previous E55 and parts and labour came to just under £200.
Don't ignore the fault. It will get worse until it just refuses to start once cooled down.
John77
Thank you.
John77
Opie (which uses the Bosch ones are cheaper) Can you get better than Bosch? What make does MB Use?
Opie are sponsors of This site aren't they?
I don't know who makes MB ones .
Yep Opie Oils are forum sponsors i believe . Also a very good company to deal with .
John77
Had to go up to Birmingham today. A round trip of around 220 miles and nothing. No light, no change in the car at all. Maybe just an hiccup last time, but I will keep an eye on it.
ajlsl600
france
Grand. But I wud have one handy and know the method and hav tooling ready
May never see issue again, maybe tomorrow no start or worse ur 200 mile from home and no start .
John77
Thank you
www.W140.co.uk&www.r129.co
