wynanddb
- Jan 21, 2009
- Location
- Port Elizabeth, South Africa
- multiple
This is a pic of my crankshaft sprocket. It looks like the chain wore through the plastic/rubber type stuff between the sprockets. Actually found parts of it in the sump. Engine (W210 E230) has 288 000km on the clock. Will prob need to replace the sprocket, or what do you think?, if anyone had any pointers I would appreciate it. A dead certain is that I will be replacing the chain tensioner, which was probably the cause in the first place. Had a pinking sound under load. Maybe I should replace the chain as well? Any advice will be apreciated
Thanks :grin:
