Crekaing/Groaning while stationary/low speed
C
C-Class
I wonder if you could help?
While stationary, if I turn the steering wheel to the right and back to centre, there is a creaking/groaning noise. It also does this at low speeds, especially turning right into junctions, or while performing three point turns?
After reading many posts on this, I bought a genuine (MB) n/s lower ball joint, and had it fitted. The old one was very worn. However, the noise is still there. I am going to replace the o/s one to be on the safe side.
The question is, am I barking up the wrong tree? I am no mechanic, but I will have a go. I have also doused all bushes/joints etc in silicone spray, but with no luck.
Any ideas folks?
whitenemesis
CLS55 AMG '05
Have a read here
Solution in my case detailed in post#14
roofless
w124 e220 estate
i have the same fault but at any speed now sorted i dont let the wife in the car
C
C-Class
Very good ;)
I should have mentioned though that I can feel the vibration up the steering column.
www.ckinsurance.co.uk
