multigrade
- Jul 16, 2023
- 1995 W124 E320 M104
I've had the W124 Coupe for six months now and the cruise control has never worked and still doesn't work. So now I'm trying to understand what the problem is.
I understand that there's no separate CC module for this model year as it's all under the management of the ECU. So I built a reader and received the following fault codes on pin 14 (which is the CC pin): 2, 5, 7, 11
The description of these faults is:
code 2: Cruise control/idle speed control module
code 5: Stop lamp switch
code 7: Data bus (CAN)
code 11: Fuel safety shut-off to LH-SFI control module
Supplementary information: I've just rewired the throttle body harness (eco insulation!) in the hopes that this might fix the problem. It didn't.
So I think I can figure out what two of the individual codes mean but the stop lamp switch fault is odd because the brake lights work, and I don't know what the CAN bus fault means. So can anyone say what this combination of faults is telling me, please?
Thanks.
Thanks.
