Cruise Control disengages by itself
Hillman
Hi All
Any ideas why the cruise control on my 2000 x reg e220 cdi would disengage itself? It's started to do this over the last few week. I can be on the M'way happy as larry on cruise then for no reason at all the cruise will go off. Not a whisper of break pedal or a touch of the stick!
I can reengage it and it will carry on happily! Any ideas?
Cheers
David Nock
South Yorks
CLK/2009/320CDI
No expert on this but I do remember a post on here a while back which suggested that the cruise might disengage if it picked up unequal rear wheel speeds, such as might be caused by one rear tyre worn more than the other.
Sorry if this is a red herring. Out of interest are all the tyres sound?
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Have you changed any tyres lately? as david says this can cause the problem your experiencing.
H
Hillman
Now that is interesting as I have just had 2 brand new Goodyears fitted to the front of the car. The rear tyres are only 12 months old and seem fine. Measured the trad and they are the same depth. Could new tyres on the front cause this??
bigasotonuk
Southampton UK
Are the tyre profiles the same as the ones that came off?
Also maybe worth checking the tyre pressures, as I have heard this can cause this but I have always doubted that the system would be that sensitive. Though later cars tyre pressures are monitored in a similar way.
Tim Green
If you look further down the page you will see a similar thread from me from about a week ago. A similar problem caused by two different pairs of tyres being fitted, with slightly different rolling circumferences. On my car the circumferences were only about 1 inch differenct and the problem occured. Try measuring with a length of string fully around the wheels and measure difference.
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Hi All
Cheers
Yep - Check tyre sizes & Makes.
Same problem as you. Chaged all 4 tyres to the same size and Make - no problems since.
blackbeauty
KERNOW
I experienced a similar promlem a couple of years ago and the MB diagnosis was.... wait for it... NEW GEARBOX, Rads and all that goes with it!!! fortunately that one was a warranty exercise.
whitenemesis
CLS55 AMG '05
This could also be a faulty brake pedal switch. Much cheaper to replace!
alec2
East Dorset
This was a well known problem on the C class of the early 2000s. I do not know if it also applied to the e class.
A wiring modification was required under warranty.
Is this a new problem on your car or could it have been there all the time?
Alec
H
Hillman
Hi Alec
It's a new prb and I have done some more testing. CC works no probs at all until it gets to over 68mph. I'm going to have the tyres balancd again to see if this helps
Cheers
Paul
JEZ.S320L
Costa Calida, Spain
Hi Alec
Cheers
Paul
Have you checked that the tyre sizes are correct/match?
Can't see it being anything to do with balancing.
alec2
East Dorset
I agree with previous posters, the problem will probably turn out to be different tires on the front and rear.
Make sure your pressures are correct.
Alec
