The Grand Wanderer
- Sep 6, 2009
- Sprinter 416 cdi /2001/2.7 with sprintshift and cruise control
Hi Guys,
I have a left hand drive Mercedes Sprinter based motorhome. It is a 2001 416cdi 2.7ltr 5 cylinder model with sprintshift, cruise control and ASR (Acceleration Slip Regulation). I was coming home through France using cruise control set at 80kph when the ASR light in the console came on and then the sprintshift dis-engaged leaving me to just coast to the side of the road but the engine running normally. Ok so I turned off the ignition and then re-started the engine engaged Auto with the selector and moved off. Put cruise control on again and the machine again went through the same process of dropping out of auto. Upon restarting I discovered that if I did not use the cruise control it would drive fine and I managed to return to the uk. So can any of you tech savvy guys tell me how to cure the fault or must I have it put on the Star computer for the ECU program to be re-installed?
Many thanks,
Wanderer
Many thanks,
Wanderer
