cruise fixing question
robparker
Taunton
I have a 1990 230ce with cruise that doesn't work, and i also have a 1983 280se with cruise that does work. basically as the 230ce is the one i use all the time i owuld like to fix the cruise in that. Can someone point me in the direction of which componants i should try removing and plugging in etc, or is it not that simple? thanks
42864
Pembrokeshire West Wales
Before you start unplugging and replacing parts check that you have a live feed to the C/C unit. I had a similar problem and after changing several parts we then found out that awire had corroded in one of the multiplugs under the bonnet result --No Feed to the C/C
Dave
wscheffer
Ohio, USA
www.scheffers.com
I agree, before you start unplugging and swapping parts around I would check to make sure that the parts are interchangeable.
Correct me if I am wrong but the 230 ce is a W124 and the 280 se is a W126 for starters.
Their is quite a difference in age and even though the Cruise Control Amplifiers may look the same their might be a change in the pin configuration and your end result may be that you end up with two vehicle that no longer have Cruise. :rolleyes:
robparker
robparker
Taunton
Ok, i did wonder if they were different, but kinda hoped the systems would be the same. I'll have a check around as suggested above anyway. thanks, rob
There are some basic check that you can do,I will try and find the details
w124nut
Somerset England
W124 cabriolet 1994 E320
I have just had a similar problem with my W124 1994 E320. The cruise control gave up the ghost. Also, the ABS light stayed on and it was this problem that would not allow the cruise to function.
Amswer: the fuse in the OVP was u/s. After changing, both systems worked perfectly.
MBFAN
Alicante, Spain
1992 300sl-24, 2012 Fiat Freemont, 2008 Opel GT 2.0 Turbo
C/C unit?
Hi, Same fault on my 1992 300 sl 24.
When you say check live to C/C unit, do you mean the cruise control ECU under the bonnet ? If so do you know which pin on the ecu plug is the live ?
